The power supply is a hot-service component that can be replaced by a customer.
Caution - This procedure requires that you handle components that are sensitive to electrostatic discharge. This discharge can cause failure of server components. |
Verify that the power supply is oriented as shown in the following figure.
As soon as power is applied to the server, standby power initializes the service processor. Depending on the server's OpenBoot PROM settings, the host server might automatically boot, or you might need to boot it manually.
