Remove the Front I/O Assembly
The front I/O assembly is a cold-service component
that can be replaced only by authorized service personnel. For the
location of this component, see Main Module Components.
| Caution - This procedure requires that
you handle components that are sensitive to electrostatic discharge.
This discharge can cause electronic components to fail. |
- Remove
the main module from the server.
See Remove the Main Module.
- Take the necessary ESD precautions.
See Prevent ESD Damage.
- Locate the front I/O assembly
on the main module.
See Main Module Components.
- Disconnect the ribbon cable that
connects the assembly to the motherboard and remove the front I/O
assembly.
- Pull the cable free
of the connector on the motherboard (panel 1).
- Push the cable connector aside
to access the captive screw that secures the assembly to the motherboard
(panel 2).
Loosen the screw to release the lower end of the assembly.
- Gently pull the front I/O assembly
toward the back of the main module until the ports at the front
of the assembly clear the front of the main module, and then remove
the front I/O assembly from the main module (panel 3).
