You can use the SP to perform a graceful shutdown of the server. This type of shutdown ensures that all of your data is saved and that the server is ready for restart.
Depending on the type of problem, you might want to view server status or log files. You also might want to run diagnostics before you shut down the server.
-> stop /System Stopping /System
