Power On the Server (Oracle
ILOM)
Note - The boot process depends on the most recent
power state of the server and on Oracle ILOM policy settings. You
must determine if the server is running before you issue the start /System command.
- Check
the server power state. Type:
-> show /System power_state
/System
Properties:
power_state = Off
- If the server is powered off,
power on the server. Type:
-> start /System
Starting /System
- (Optional.)
To view server boot output, start a host console stream. Type:
-> start /HOST/console
- If you are adding a second processor
module, return to Server Upgrade Process.
