Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Changes the current target.
cd [-default] target
where target is the target and path to act upon.
This Oracle ILOM command changes the Oracle ILOM attention to the specified target. This command is similar to the change directory (cd) command of many operating systems.The -default option returns the attention to the default target.
This example shows how to change to the /SP/logs/event/list target with the cd command.
Note - The output in the example is a portion of the full output.
-> cd /SP/logs/event/list /SP/logs/event/list -> show /SP/logs/event/list Targets: Properties: Commands: cd s how ID Date/Time Class Type Severity ----- ------------------------ -------- -------- -------- 75 Wed Oct 7 20:12:31 2009 Audit Log minor root : Open Session : object = /session/type : value = shell : success 74 Wed Oct 7 20:12:28 2009 Audit Log minor root : Close Session : object = /session/type : value = shell : success 73 Wed Oct 7 20:11:21 2009 Audit Log minor root : Open Session : object = /session/type : value = shell : success . . . ->
