Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays links presence.
listlinkup [link][peer][internal|all|connected]
This hardware command lists the presence of links and the up-down state of the associated ports on the switch chip.� The listlinkup command also accepts these arguments:
link – Displays additional information about the links.
peer – Displays additional information about the peer ports.
internal – Displays only links between the I4 switch chip and the BridgeX chips.
all – Displays all link types.
connected – Displays only links that are connected to other nodes.
The listlinkup command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display comprehensive information about all link presence, associated ports, link state, and information about the peers with the listlinkup command.
FabMan@gateway_name->listlinkup link peer all Connector 0A Not present Connector 1A Not present Connector 2A Not present Connector 3A Present <-> Switch Port 26 down (Enabled) Link state: Down (Polling) speed: 4xSDR MTU: 4096 VLs: 0-7 Peer: "" Peerport: 0 NodeGUID: 0x0000000000000000 LID: 0x0000 Connector 4A Not present Connector 5A Present <-> Switch Port 30 up (Enabled) Link state: Active (LinkUp) speed: 4xQDR MTU: 2048 VLs: 0-7 Peer: "o4test56 HCA-1" Peerport: 1 NodeGUID: 0x0021280001cf205a LID: 0x0008 Connector 6A Not present Connector 7A Present <-> Switch Port 33 up (Enabled) Link state: Active (LinkUp) speed: 4xQDR MTU: 2048 VLs: 0-7 Peer: "o4test57 HCA-1" Peerport: 1 NodeGUID: 0x0021280001cf3786 LID: 0x0014 Connector 8A Not present Connector 9A Not present Connector 10A Not present Connector 11A Not present Connector 12A Not present Connector 13A Not present Connector 14A Not present Connector 15A Not present Connector 0A-ETH Present Bridge-0 Port 0A-ETH-1 (Bridge-0-2) up (Enabled) Bridge-0 Port 0A-ETH-2 (Bridge-0-2) up (Enabled) Bridge-0 Port 0A-ETH-3 (Bridge-0-1) up (Enabled) Bridge-0 Port 0A-ETH-4 (Bridge-0-1) up (Enabled) Connector 1A-ETH Present Bridge-1 Port 1A-ETH-1 (Bridge-1-2) up (Enabled) Bridge-1 Port 1A-ETH-2 (Bridge-1-2) up (Enabled) Bridge-1 Port 1A-ETH-3 (Bridge-1-1) up (Enabled) Bridge-1 Port 1A-ETH-4 (Bridge-1-1) up (Enabled) Connector 0B Not present Connector 1B Not present Connector 2B Not present Connector 3B Not present Connector 4B Not present Connector 5B Not present Connector 6B Not present Connector 7B Not present Connector 8B Not present Connector 9B Not present Connector 10B Not present Connector 11B Not present Connector 12B Not present Connector 13B Not present Connector 14B Not present Connector 15B Not present Link Switch Port 1 <-> Bridge-1 Port Bridge-1-2 up Link state: Active (LinkUp) speed: 4xQDR MTU: 4096 VLs: 0-1 Peer: "SUN IB QDR GW switch o4nm2-gw-6 10.172.144.77 Bridge 1" Peerport: 2 NodeGUID: 0x00212856d102c040 LID: 0x0005 Link Switch Port 2 <-> Bridge-1 Port Bridge-1-1 up Link state: Active (LinkUp) speed: 4xQDR MTU: 4096 VLs: 0-1 Peer: "SUN IB QDR GW switch o4nm2-gw-6 10.172.144.77 Bridge 1" Peerport: 1 NodeGUID: 0x00212856d102c040 LID: 0x0004 Link Switch Port 3 <-> Bridge-0 Port Bridge-0-2 up Link state: Active (LinkUp) speed: 4xQDR MTU: 4096 VLs: 0-1 Peer: "SUN IB QDR GW switch o4nm2-gw-6 10.172.144.77 Bridge 0" Peerport: 2 NodeGUID: 0x00212856d102c000 LID: 0x0003 Link Switch Port 4 <-> Bridge-0 Port Bridge-0-1 up Link state: Active (LinkUp) speed: 4xQDR MTU: 4096 VLs: 0-1 Peer: "SUN IB QDR GW switch o4nm2-gw-6 10.172.144.77 Bridge 0" Peerport: 1 NodeGUID: 0x00212856d102c000 LID: 0x0002 FabMan@gateway_name->
