Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Verifies voltages.
checkvoltages
This hardware command displays the internal voltages for the main board. On the left side of the equals sign is the expected voltage. On the right side of the equals sign is the measured voltage. If the difference between the expected voltage and the measured voltage is more than 10%, the cause should be investigated. The command also provides a summary of the voltage conditions.
The checkvoltages command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to check that voltages are at nominal values with the checkvoltages command.
FabMan@gateway_name->checkvoltages Voltage ECB OK Measured 3.3V Main = 3.30 V Measured 3.3V Standby = 3.42 V Measured 12V = 12.06 V Measured 5V = 5.03 V Measured VBAT = 3.17 V Measured 1.0V = 1.01 V Measured I4 1.2V = 1.22 V Measured 2.5V = 2.51 V Measured V1P2 DIG = 1.18 V Measured V1P2 ANG = 1.18 V Measured 1.2V BridgeX = 1.22 V Measured 1.8V = 1.80 V Measured 1.2V Standby = 1.20 V All voltages OK FabMan@gateway_name->
