Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Queries InfiniBand fabric administration attributes.
saquery [-h][-d][-p][-N][-D][-S][-I][-L][-l][-G][-O][-U][-c][-s] [-g][-m][-x][-C ca_name][-P ca_port][-t timeout][--src-to-dst source:destination][--sgid-to-dgid source-destination][name|lid|guid]
where:
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
lid is the local identifier.
guid is the global unique identifier.
name is the query name described in this table.
This InfiniBand command performs the selected Subnet Administrator query. Node records are queried by default.
The saquery command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This table describes the options to the saquery command and their purposes.
This example shows how to produce a node record dump of every LID in the InfiniBand fabric with the saquery command.
Note - The output in the example is a portion of the full output.
FabMan@gateway_name->saquery NodeRecord dump: lid.....................0xE reserved................0x0 base_version............0x1 class_version...........0x1 node_type...............Channel Adapter num_ports...............0x2 sys_guid................0x0003ba000100e38b node_guid...............0x0003ba000100e388 port_guid...............0x0003ba000100e38a partition_cap...........0x80 device_id...............0x673C revision................0xA0 port_num................0x2 vendor_id...............0x2C9 NodeDescription.........mnm33-43 HCA-1 NodeRecord dump: lid.....................0xF reserved................0x0 . . . FabMan@gateway_name->
saquery man page
