Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays help for a command.
help command | class
where:
command is the command for which you need help.
class is the category of commands.
This hardware command provides help information for supported commands. Typically, the same information is provided using the -h option.
The help command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to get help with the help command.
FabMan@gateway_name->help List of avaliable classes: general -- General commands diag -- Switch diagnostics commands ibdiag -- Infiniband diagnostics commands sm -- Subnet Managager administration commands other -- Other managagement commands all -- Show all commands Type "help" followed by a class name for a list of commands in that class. Type "help" followed by a command name for description and usage of the command. FabMan@gateway_name->
Gateway Remote Management, help command
