Skip Navigation Links
Exit Print View
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Installation
Understanding the Gateway
Gateway Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
NET MGT Connector and Pins
Data QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding Data Cabling
Preparing to Install the Gateway
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Optical Fiber Data Cables
Route the Data Cables
Installing the Gateway
Install the Gateway in the Rack
Powering On the Gateway
Connecting Data cables
Administration
Troubleshooting the Gateway
Gateway Hardware Problems
InfiniBand Fabric Problems
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Switch GUIDs Overview
Configuration Overview
Oracle ILOM Command Overview
Hardware Command Overview
InfiniBand Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Monitoring Gateway Resources
Controlling LAGs
Controlling VLANs and VNICs
Controlling Gateway Ports and Parameters
Remote Management
Understanding Oracle ILOM on the Gateway
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Gateway Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Gateway Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (Oracle ILOM)
help Command (Oracle ILOM)
load Command
reset Command
set Command
show Command
version Command (Oracle ILOM)
Service
Detecting and Managing Faults
Interpreting Status LEDs
Managing Faulty Components
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Evaluating Sensor Alarms
Accessing CLI Prompts
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Determine If a Power Supply Is Faulty
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Determine If a Fan Is Faulty
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing Data Cables
Inspecting the Data Cables
Remove a Data Cable
Install a Data Cable
Servicing the Battery
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Replace the Battery
Reference
addlagport Command
allowhostconfig Command
autodisable Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
create_ipoib Command
createfabric Command
createlag Command
createvlan Command
createvnic Command
dcsport Command
delete_ipoib Command
deletelag Command
deletevlan Command
deletevnic Command
dellagport Command
disablecablelog Command
disablegwport Command
disablelagmode Command
disablelinklog Command
disablesm Command
disableswitchport Command
disablevnic Command
disallowhostconfig Command
enablecablelog Command
enablegwport Command
enablelagmode Command
enablelinklog Command
enablesm Command
enableswitchport Command
enablevnic Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
localmkeypersistence Command
matchtopology Command
modifyvnic Command
setcontrolledhandover Command
setdefaultgwdiscpkey Command
setgwethport Command
setgwinstance Command
setgwsl Command
setgwsystemname Command
sethostvniclimit Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsmrouting Command
setsubnetprefix Command
showdisk Command
showfree Command
showfruinfo Command
showgwconfig Command
showgwports Command
showioadapters Command
showlag Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
showvlan Command
showvnics Command
smconfigtest Command
smnodes Command
smpartition Command
smsubnetprotection Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Index
showgwports Command
Displays gateway port status.
Syntax
showgwports [-v][-h]
Description
This hardware command displays information about the gateway Ethernet ports. The information includes:
This table describes each of the columns of the output
Column Heading
Description
NodeGUID
GUID for the BridgeX CA node
NodeDescription
Node description test for the BridgeX CA node.
Device
BridgeX device identifier.
Port
Internal BridgeX port number.
Portname
A construct of the BridgeX device identifier and the internal BridgeX port number.
PeerPort
The I4 switch chip port connected to the internal BridgeX port.
PortGUID
The GUID for the internal BridgeX port.
LID
The LID for the internal BridgeX port.
IBState
The combination of the InfiniBand port logical and physical state. Can be:
  • Sleep
  • Polling
  • Disabled
  • Training
  • Recovery
  • Init
  • Armed
  • Active
GWState
The gateway state for the port. Can be:
  • Reset
  • Start
  • Join Mcast
  • Join Fabric
  • Up
  • Error
Speed
Maximum available speed for the link.
VLs
Number of operational virtual lanes.
MTU
MTU.
Bridge
Adminstate
State set by the enablegwport and disablegwport commands. Either enabled or disabled.
Link
Physical state of the link. Either Up or Down.
State
Logical state of the gateway port. Can be:
  • Start
  • Join Mcast
  • Join Fabric
  • Up
  • Error
TxPause
Transmit flow control. Can be:
  • None
  • 0-255 PFC
  • Global
RxPause
Receive flow control. Can be:
  • None
  • 0-255 PFC
  • Global
Linkmode
Link mode of the Ethernet port.
The showgwports command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
Options
This table describes the options to the showgwports command and their purposes.
Option
Purpose
-v
Displays verbose output.
-h
Provides help.
Example
This example shows how to display verbose information about the gateway Ethernet ports using the showgwports command.
Note - Your output will differ from that of the example.
FabMan@gateway_name->showgwports -v
BRIDGE DEVICES:
NodeGUID           NodeDescrition
0x00212856d102c000 SUN IB QDR GW switch o4nm2-gw-6 10.172.144.77 Bridge 0
0x00212856d102c040 SUN IB QDR GW switch o4nm2-gw-6 10.172.144.77 Bridge 1
INTERNAL PORTS:
Device   Port Portname  PeerPort PortGUID           LID    IBState  GWState     Speed  VLs MTU
Bridge-0  1   Bridge-0-1    4    0x00212856d102c001 0x0002 Active   Up          40Gbs    2 4096
Bridge-0  2   Bridge-0-2    3    0x00212856d102c002 0x0003 Active   Up          40Gbs    2 4096
Bridge-1  1   Bridge-1-1    2    0x00212856d102c041 0x0004 Active   Up          40Gbs    2 4096
Bridge-1  2   Bridge-1-2    1    0x00212856d102c042 0x0005 Active   Up          40Gbs    2 4096
CONNECTOR 0A-ETH:
Port      Bridge      Adminstate Link  State       MTU  TxPause  RxPause        Linkmode       Speed
0A-ETH-1  Bridge-0-2  Enabled    Up    Up          9600 Global   Global         XFI            10Gb/s
0A-ETH-2  Bridge-0-2  Enabled    Up    Up          9600 Global   Global         XFI            10Gb/s
0A-ETH-3  Bridge-0-1  Enabled    Up    Up          9600 Global   Global         XFI            10Gb/s
0A-ETH-4  Bridge-0-1  Enabled    Up    Up          9600 Global   Global         XFI            10Gb/s
CONNECTOR 1A-ETH:
1A-ETH-1  Bridge-1-2  Enabled    Up    Up          9600 Global   Global         XFI            10Gb/s
1A-ETH-2  Bridge-1-2  Enabled    Up    Up          9600 Global   Global         XFI            10Gb/s
1A-ETH-3  Bridge-1-1  Enabled    Up    Up          9600 Global   Global         XFI            10Gb/s
1A-ETH-4  Bridge-1-1  Enabled    Up    Up          9600 Global   Global         XFI            10Gb/s
Related Information
