Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Sets the subnet prefix.
setsubnetprefix prefix|list
where prefix is the hexadecimal prefix.
This hardware command sets the subnet prefix for the InfiniBand fabric. The prefix is entered in hexadecimal, starting with 0x and having lower case alphanumeric characters. The list option provides a listing of the Subnet Manager settings in respect to priority, controlled handover, and subnet prefix.
The setsubnetprefix command writes the value of prefix to the subnet_prefix parameter of the configuration file.
Note - You must stop or disable the Subnet Manager before using the setsubnetprefix command. See disablesm Command.
The setsubnetprefix command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to set the subnet prefix to 0xabbababe with the setsubnetprefix command.
FabMan@gateway_name->setsubnetprefix 0xabbababe Current SM settings: smpriority 5 controlled_handover TRUE subnet_prefix 0xabbababe M_Key None Routing engine FatTree FabMan@gateway_name->
