Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Creates a VNIC.
createvnic connector|lagname <-guid guid>|<-host hostname -port port>|<-node string -port port> [-mac mac][-vlan vlan_ID] -pkey p_key [-n][-h]
where:
connector is the name of the connector (0A-ETH-1 to 0A-ETH-4 and 1A-ETH-1 to 1A-ETH-4).
lagname is the identifier of the LAG
guid is the global unique identifier of the target port on the host associated with the VNIC.
hostname is the host name of the management controller or system name recognized by the BridgeX manager.
port is the port of the host.
string is the character string in the node description field.
mac is the MAC address.
Note - Only even numbers are supported for the most significant byte of the MAC address (unicast).
Note - You must assign a MAC when you create a VNIC. If you have forgotten, you can assign the MAC with the modifyvnic command.
vlan_ID is the VLAN identifier (NO or 2 to 4094).
Note - Do not use VLAN identifiers 0, 1, or 4095. According to the IEEE 802.1Q specification, VLAN ID 0 is used for priority tag, and VLAN ID 1 is usually reserved for a switch or bridge management VLAN.
p_key is the partition key (1 to 7fff or default).
This hardware command creates a VNIC for a specific connector. When a VNIC is created, it is automatically assigned an ID number. You can see this ID number with the showvnics command.
Note - For VNICs created by the createvnic command, the Network Interface names at the host which is set by the DEVICE parameter in the ifcfg-ethX (where X is identifier), the name should be different from eth0 to eth7, since these names are reserved for devices created and controlled from the host. A suggested name scheme would be ethgateway_instance_VNIC_ID, but all names apart for eth0 to eth7 would be valid.
The createvnic command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the createvnic command and their purposes.
This example shows how to create a VNIC with the default partition key using the createvnic command.
FabMan@gateway_name->createvnic 1A-ETH-2 -guid 00:21:28:00:01:3E:93:f7 -mac 02:02:03:00:01:57 -pkey default VNIC created FabMan@gateway_name->
