Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays primary (or Master) Subnet Manager node information.
getmaster [-l]
This hardware command returns information about the node that hosts the primary (or master) Subnet Manager of the InfiniBand fabric. The -l option provides a short historical list of Subnet Manager activity.
The getmaster command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display information about the node that hosts the master Subnet Manager with the getmaster command.
FabMan@gateway_name->getmaster -l Local SM enabled and running, state MASTER SM monitoring history: 20121212 15:05:05 whereismaster stopped 20121212 15:09:03 whereismaster started 20121212 15:09:03 Master SubnetManager on sm lid 1 sm guid 0x3baabba015c0a0 : SUN IB QDR GW switch o4nm2-gw-4 10.172.144.72 20121212 15:11:31 No Master SubnetManager seen in the system . . . FabMan@gateway_name->
