Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays information about IOAs.
showioadapters [--withlimit][-h]
This hardware command displays the I/O adapter GUID to LID to gateway connector mapping. An I/O adapter (IOA) represents a HCA port with an EoIB driver, that is able to reach the relevant gateway instance. The output of the command is in tabular form. This table describes each of the columns of the output.
The showioadapters command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the showioadapters command and their purposes.
This example shows how to display information about the I/O adapters with the showioadapters command.
FabMan@gateway_name->showioadapters IOA_GUID NODE LID FLAGS GW ----------------------- ---------- ---- ------ ----- 0021280001CF205B o4test56 8 ND 1A-ETH-2 0021280001CF3787 o4test57 14 HD 1A-ETH-2 0021280001CF205B o4test56 8 ND 1A-ETH-1 . . . 0021280001CF3787 o4test57 14 ND 0A-ETH-3 0021280001CF205B o4test56 8 HD 0A-ETH-4 0021280001CF3787 o4test57 14 ND 0A-ETH-4 FabMan@gateway_name->
