Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Creates topology file.
generatetopology topofile|[-h]
where topofile is the filename and path to the topology file.
This hardware command creates a topology file of the InfiniBand fabric. This file is not compatible with the topology file created by the ibnetdiscover command. The generatetopology command is used with the matchtopology and showtopology commands to determine changes in the InfiniBand fabric. The -h option provides help.
The generatetopology command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to create a topology file called Topo.conf with the generatetopology command.
FabMan@gateway_name->generatetopology AUG22.topo It will take some time to generate a topology file. Please wait! topo.conf file is created. Will now start generating the topo file Wrote Topology file: AUG22.topo FabMan@gateway_name->
This is a portion of a topology file created by the generatetopology command.
Note - Your topology file will differ.
SUNIBQDRGW mnm34-98 Bridge 0 BX1/P1 -4x-10G-> I4_GENERIC mnm34-98 P4 -4x-10G-> I4_GENERIC mnm34-98 P3 BX3/P1 -4x-10G-> I4_GENERIC mnm34-98 P2 -4x-10G-> I4_GENERIC mnm34-98 P1 DEV26428_02P mnm34-55_HCA-1 P1 -4x-10G-> SUNIBQDRGW mnm34-97 C-7A P2 -4x-10G-> I4_GENERIC mnm34-98 P33 SUNIBQDRGW mnm34-97 A-SW/P2 -4x-10G-> SUNIBQDRGW mnm34-97 BX3/P1 A-SW/P4 -4x-10G-> SUNIBQDRGW mnm34-97 BX1/P1 C-0B -4x-10G-> I4_GENERIC mnm34-98 P21 C-0A -4x-10G-> I4_GENERIC mnm34-98 P20 C-1B -4x-10G-> I4_GENERIC mnm34-98 P19 C-1A -4x-10G-> I4_GENERIC mnm34-98 P22 C-2B -4x-10G-> I4_GENERIC mnm34-98 P24 C-2A -4x-10G-> I4_GENERIC mnm34-98 P23 . . . DEV26428_02P mnm34-60_HCA-1 P1 -4x-10G-> SUNIBQDRGW mnm34-97 C-8A P2 -4x-10G-> I4_GENERIC mnm34-98 P31 # Created from mnm34-98 at Thu Aug 19 13:32:25 PDT 2010
