Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays port counters.
getportcounters port|connector [-R]
where:
port is the number of the port (1 to 36).
connector is the name of the connector (0A to 15A, 0A-ETH, 1A-ETH, 0B to 15B).
Note - The subordinate names of the 10 GbE connectors, 0A-ETH-1 to 0A-ETH-4 and 1A-ETH-1 to 1A-ETH-4 are also valid connector names.
This hardware command returns the error and data throughput counters of the specified port of the switch chip or connector of the gateway. If a port is specified, then the output is for InfiniBand counters. Similarly, if the connector specified is 0A to 15B, the output is also for InfiniBand counters. If the connector specified is 0A-ETH, 1A-ETH, or a subordinate connector, the output is for 10GbE counters.
The -R option clears the counters for the specified port or connector.
The getportcounters command is available from the /SYS/Switch_Diag, /SYS/Gateway_Mgmt, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the status of connector 1A-ETH-1 with the getportcounters command.
FabMan@gateway_name->getportcounters 1A-ETH-1 Port counters for connector 1A-ETH-1 Bridge-1 port Bridge-1-2 RX bytes.........................8832 RX packets.......................69 RX Jumbo packets.................0 RX unicast packets...............0 RX multicast packets.............69 RX broadcast packets.............0 RX no buffer.....................0 RX CRC...........................0 RX runt..........................0 RX errors........................0 TX bytes.........................8832 TX packets.......................69 TX Jumbo packets.................0 TX unicast packets...............0 TX multicast packets.............69 TX broadcast packets.............0 TX errors........................0 FabMan@gateway_name->
