Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Displays information about configured LAGs.
showlag [lagname][-h]
where lagname is the identifier of the LAG.
This hardware command displays information about configured LAGs. If no lagname is specified, then the command displays general information about all configured LAGs. The output of the command is in tabular form. This table describes each of the columns of the output.
The -h option provides help.
The showlag command is available from the /SYS/Gateway_Mgmt and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example show how to display information about all configured LAGs with the showlag command.
FabMan@gateway_name->showlag Name Iport Members Vnics Gw Port ID BANDWIDTH Distribution LACP Mode DiscoverPkey Type SL ---------- ---------- ------- ----- ---------- --------- ------------ ---------- ------------ ------ ---- bxmtest0 Bridge-0-1 0 1000 2704 NA NA NA 0xffff Global 1 FabMan@gateway_name->
This example shows how to display information about the LAG named test with the showlag command.
FabMan@gateway_name->showlag test Name enabled active RC ---------- ------- ------ --- 0A-ETH-2 1 1 0x0 0A-ETH-3 1 1 0x0 FabMan@gateway_name->
