Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Acquire the BXOFED Software (Linux)
Install the BXOFED Software (Linux)
Acquire the ConnectX-2 Firmware
Gateway Manual Mode Overview (Linux)
Determine VNIC Configuration Parameters For Gateway Manual Mode (Linux)
Determine VLAN Associations for Gateway Manual Mode (Linux)
Configure and Create VNICs for Gateway Manual Mode (Linux)
VNIC Configuration on Linux Hosts in Gateway Manual Mode
Creating VNICs Under Host Manual Mode (Linux)
Host Manual Mode Overview (Linux)
Central Configuration File (Linux)
VNIC-Specific Configuration File (Linux)
Determine VNIC Configuration Parameters for Host Manual Mode (Linux)
Create the Central Configuration File (Linux)
Create the VNIC-Specific Configuration Files (Linux)
mlx4_vnic_confd Daemon (Linux)
Configure and Create VNICs for Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Ethernet Over InfiniBand Overview (Oracle Solaris)
Verify That the Ethernet Over InfiniBand Driver Is Installed (Oracle Solaris)
Install the Ethernet Over InfiniBand Driver (Oracle Solaris)
Configure IP Addresses on the Data Link (Oracle Solaris)
Create Oracle Solaris VNICs With VLAN Tagging (Oracle Solaris)
Display Gateway Ethernet Port Information
Display Gateway Port Information
Display the Gateway Instance Number
Display Information About the Gateway
Add or Delete Connectors From a LAG
VNIC Allocation on the Gateway
Controlling Gateway Ports and Parameters
Enable a Gateway Ethernet Port
Disable a Gateway Ethernet Port
Set the Gateway Ethernet Port Parameters
Set the Gateway Instance Number
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
These topics describe how to create VNICs under gateway manual mode:
