Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Sets persistence of the M_Key.
localmkeypersistence enable|disable|show|help
This hardware command sets the persistence of the M_Key used by the I4 switch chips to survive a reboot of the management controller. The command has four arguments:
enable – After a reboot, the local M_Key is restored before enabling the I4 switch chip ports.
disable – After a reboot, the previous local M_Key is lost and no local M_Key is set before the Subnet Manager becomes operational.
show – Displays the local M_Key persistence status.
help – Provides help.
The localmkeypersistence command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to display the local M_Key persistence status with the localmkeypersistence command.
FabMan@gateway_name->localmkeypersistence show Local M_Key persistence is enabled. Local M_Key will be restored after reboot before switch ports are enabled. FabMan@gateway_name->
Gateway Administration, enabling secret M_Key persistence
