Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
InfiniBand Connector Status Window
Gateway Connector Status Window
InfiniBand Connector Parameters and Status
Gateway Connector Parameters and Status
I4 to Gateway Interface Parameters and Status
I4 Switch Chip Port Parameters and Status
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
This figure displays the basic aspects of the FM interface.
Note - Both the control panel and legend are hidden by default. Clicking the more>> link makes them visible.
The FM also has status windows for:
Connector indicators – Moving the mouse cursor over an indicator that is orange or red opens a small window that provides the reason for the respective state.
InfiniBand connector status – Clicking on a gray InfiniBand connector opens a window that displays connector FRU, port state, error, and statistical information for that connection.
Gateway connector status – Clicking on a gray gateway connector opens a window that displays connector FRU and port information for that connection.
BridgeX port status – Clicking on a gateway BX indicator opens a window that displays port information for the interface between the I4 switch chip port and the BridgeX chip port.
These status windows are explained in depth in Accessing the Rear Panel Diagram.
