Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
InfiniBand Connector Status Window
Gateway Connector Status Window
InfiniBand Connector Parameters and Status
Gateway Connector Parameters and Status
I4 to Gateway Interface Parameters and Status
I4 Switch Chip Port Parameters and Status
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
This figure provides an example of the IB Port Map tab.
The IB Port Map tab displays information about peer devices attached to the gateway. A table describes this information:
Connector – Rear panel connector respective to the I4 switch chip port
I4 Port – Port of the I4 switch chip
Type – Type of peer device attached to the connector or I4 switch chip port
Name – Contents of the peer device's NodeDescription field
GUID – GUID of the peer device
LID – LID assigned to the peer device
Port – Port of the node identified by the GUID or LID
Note - You must select the Poll I4 checkbox (default) in the control panel to populate the table with current information.
By clicking on a column heading, the information in the table is sorted according to that column heading, either in ascending or descending order. For example, clicking the Connector heading sorts the information in the table according to the numeric sequence of the connectors. Clicking the peer device Name heading sorts the information in the table according to the NodeDescription field of the peer device.
