Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
InfiniBand Connector Status Window
InfiniBand Connector Parameters and Status
Switch Connector Parameters and Status
I4 Switch Chip Port Parameters and Status
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
This figure provides an example of the IB Performance tab.
The IB Performance tab displays the status of the I4 switch chip ports. A table describes this information:
Connector – Rear panel connector respective to the I4 switch chip port
I4 Port – Port of the I4 switch chip
Link Status – Present link state of the that port. Either Down (yellow) or Active (green)
RX B/w (Gbps) – Instantaneous receive link bandwidth for that port
TX B/w (Gbps) – Instantaneous transmit link bandwidth for that port
By clicking Show Chart, a sixth column for the table is displayed:
B/W (Gbps) – Running bandwidth of the link for that port (0 to 40 Gbps)
Note - You must select the Poll I4 checkbox (default) in the control panel to populate the table with current information.
When displaying the B/W (Gbps) column, the added resource demand on the management controller slows its ability to display the information. Clicking Hide Chart removes the bandwidth charts.
By clicking on a column heading, the information in the table is sorted according to that column heading, either in ascending or descending order. For example, clicking the I4 Port heading sorts the information in the table according to the numeric sequence of the I4 ports. Clicking the Link Status heading sorts the information in the table according to the state of the links.
