Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Display Subnet Manager Location History
Display the Secret M_Key Configuration
Verify the Subnet Manager Configuration Integrity
Display the Subnet Manager Log
Set the Subnet Manager Priority
Enable Subnet Manager Controlled Handover
Set the Subnet Manager Readable Management Key
Clear the Subnet Manager Readable Management Key
Set the Subnet Manager Routing Algorithm
Configuring Secure Fabric Management
Prepare for Secret M_Key Functionality
Create the Secret M_Key Configuration
Add Secret M_Keys to the Configuration
Delete Secret M_Keys From the Configuration
Configure a Local Secret M_Key
Enable or Disable Secret M_Key Persistence
Enable or Disable Secret M_Key Functionality
Considering Situations In Regard to Secret M_Key
Add a New Subnet Manager to the Secret M_Key Fabric
Merge Subnets Into One Secret M_Key Fabric
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Follow these guidelines for firmware upgrades and downgrades with respect to secret M_Key functionality:
For ease of use, upgrade all firmware to version 2.1 or later before implementing secret M_Key.
If you downgrade to firmware version 2.0 or earlier, you lose secret M_Key functionality. Disable secret M_Key functionality before the downgrade, otherwise the remaining secret M_Key portions of the fabric become undiscoverable by the downgraded switch or gateway.
This table describes the firmware type of M_Key functionality and its support by the firmware versions.
Note - Readable M_Keys created in firmware versions 2.0 or 2.1 are functional under either firmware versions.
