Figure 59 Fabric Interconnect Power Switch
When the Fabric Interconnect completes the boot process, a prompt is displayed on the serial console.
XsigoLinux 120 (2006/09/07 11:43:18) local ttyS0 local login: admin Password: admin
Once you have successfully logged in, the Configuration Wizard will automatically launch.
Would you like to use the Oracle Configuration Wizard? [Y/n] y Hostname: ovn123 Domain: oracle.com (or blank)Is this Interconnect to be designated as the IB subnet manager? [Y/n] y Do you want this Interconnect to send diagnostic data to Oracle periodically? [Y/n] y Please input the 'admin' password: **** (unlimited length) Please confirm the 'admin' password: **** Please input the 'recovery-password': **** (unlimited length) Please confirm the 'recovery-password': **** IP Address [static/DHCP]: DHCP Management IP Address [X.X.X.X]: (appears only if static addressing is selected) Subnet Mask [X.X.X.X]: (appears only if static IP addressing is selected) Default Gateway [X.X.X.X]: (appears only if static IP addressing is selected) Enter DNS Server 1: (appears only if static IP addressing is selected) Enter DNS Server 2: (appears only if static IP addressing is selected) Enter DNS Server 3: Enter NTP Server 1: hostname, IP address, or blank Enter NTP Server 2: hostname, IP address, or blank Enter NTP Server 3: Supply the SNMP Read Community Name (leave blank if you want to keep the default of 'public')
When you have completed the configuration, the Oracle Configuration Wizard closes and returns you to the admin@<system_name> prompt.
