This section documents how to remove and install a power supply (PSU). You can replace one PSU at a time without powering down the Fabric Interconnect. For this procedure, you will need a #2 Phillips (cross-head) screwdriver.
Caution - When tightening screws, make sure to tighten them to lightly snug. Do not overtighten screws or they can break. |
Caution - When replacing the Power Supplies: - wear an ESD wrist strap - When the hardware is out of its shipping package or not in the Fabric Interconnect chassis, make sure you place it in an ESD safe bag or on a grounded work surface such as a rubberized work mat. |
See the appropriate section:
