Oracle Fabric Interconnect Hardware User's Guide
Exit Print View
Updated: July 2016
Removing Fan Modules
This section documents how to remove and install a fan module. You can do this procedure on one fan module at a time without powering down the Fabric Interconnect. To remove fan modules, you will need a #2 Phillips (cross-head) screwdriver.
Caution
Caution  -  When tightening screws, make sure to tighten them to lightly snug. Do not overtighten screws or they can break.
Caution
Caution  -  When replacing the Fan Modules: - wear an ESD wrist strap - When the hardware is out of its shipping package or not in the Fabric Interconnect chassis, make sure you place it in an ESD safe bag or on a grounded work surface such as a rubberized work mat.
See the appropriate section:
