Install a Fabric Interconnect F1-15 Management Module
Note -
When re-installing the Management module, ensure that the module's
component side is facing towards the right edge of the chassis. Also, make
sure that the module's top and bottom edges are correctly aligned with the
upper and lower tracks at the left edge of the Management module's slot,
which is labelled M.
Slide the module into the slot until you feel the connectors begin to
seat.
Carefully, but firmly, press the Management module into the slot until the
module's faceplate is flush with those of the other I/O modules.
Tighten the screw.
Reattach cables as necessary.
