The 4-Port 10 GE module can be swapped into a slot that previously contained another type of Ethernet I/O Module. Even though the module will install mechanically in the slot due to all I/O Modules having the same dimensions, the software is not guaranteed to preserve the correct number and configuration of vNICs from the previous module to the 4-Port 10 GE module. For example, if you remove a 1-Port 10 GE module (1x10) and insert a 4-Port 10 GE module, there is no guarantee that the previous configuration from the 1-Port 10 GE module (10x1) will be available when the 4-Port 10 GE module boots up.
As a result, if you will be using a 4-Port 10 GE module, you can either install it in a slot that previously had no other module in it, or you can install it in a module that previously had a GE module. The following procedure documents how to upgrade a previous 10-Port, 1 GE module to the 4-Port 10 GE module. For illustrative purposes, the procedure assumes that a module exists in slot 4, and the 4x10 module will be inserted into that slot. However, the 4-Port GE module does not always need to be inserted in the same slot. You can install it in a different slot if needed.
To upgrade to a 4-Port 10 GE Module follow this procedure:
set vnic <vnic-name> -if=none set vnic <vnic-name> -if=none set vnic <vnic-name> -if=none set vnic <vnic-name> -if=none
set ethernet-card 4 down
remove iocard 4
set vnic <vnic-name> -if=4/1 set vnic <vnic-name> -if=4/2 set vnic <vnic-name> -if=4/3 set vnic <vnic-name> -if=4/4
As an alternative, if you are installing the 10-Port GE module into a different slot (for example, slot 5) you can re-terminate the vNICs from the old 10-Port 1 GE module on that new slot. For example:
set vnic <vnic-name> -if=5/1 set vnic <vnic-name> -if=5/2 set vnic <vnic-name> -if=5/3 set vnic <vnic-name> -if=5/4
