With the exception of the Management module, which must be installed in slot 16 of the Fabric Interconnect F1-15's module bay, the I/O modules can be installed in any of the remaining 15 slots. All I/O modules except the Management module can be installed or removed while the system is running. For information about removing and installing the Management module, see Removing and Installing the Management Module.
To perform this procedure, you will need a #2 Phillips (cross-head) screwdriver.
Caution - When tightening screws, make sure to tighten them to lightly snug. Do not overtighten screws or they can break. |
To remove and insert a Fabric Interconnect F1-15 I/O module, follow this procedure:
Figure 91 Fabric Interconnect F1-15 I/O Module Locking Handle
