Remove a Fabric Interconnect F1-15 Management Module
On a Fabric Interconnect F1-15, the Management module can only be installed in
slot 16, which is labelled M.
To remove the Fabric Interconnect F1-15 Management module, follow this
procedure:
Power down the Fabric Interconnect.
Disconnect any cables attached to the Management module.
Using the screwdriver, release the spring-loaded securing screw (1),
located at the bottom edge of the module. See Removing the Fabric Interconnect F1-15 Management Module.
Grasp the handle (2) and withdraw the module from the chassis.
Figure 95 Removing the Fabric Interconnect F1-15 Management Module
