Replace the Fabric Interconnect F1-15 DDR Fabric Board
To replace the Fabric Interconnect F1-15 fabric board, follow this procedure:
Power down the Fabric Interconnect.
Disconnect all cables attached to the server ports, as well as any other
cables that could interfere with the Fabric Board's removal.
Using a screwdriver, loosen the captive screws in the release levers by
turning them counterclockwise (1). See Unlocking the Fabric Interconnect F1-15 Fabric Board.
Figure 69 Unlocking the Fabric Interconnect F1-15 Fabric Board
Grasp both of the Fabric Board's release levers, and simultaneously swing
them outward (2).
Grasping both of the release levers, slide the Fabric Board out of the
chassis. See Removing the Fabric Interconnect F1-15 Fabric Board.
Figure 70 Removing the Fabric Interconnect F1-15 Fabric Board
Installation is the reverse of this procedure.
