Go to main content
Netra Modular System Service Manual Supplement
Exit Print View
Updated: December 2016
Deactivate an ASR Asset
Before You Begin
An FMM, node, or switch can be configured as an ASR asset. If it is configured as an ASR asset, then you must deactivate it before servicing or replacing it.
  1. Log in to the ASR Manager.
  2. At the ASR Menu, type:/opt/asrmanager/bin/asr.
  3. At the ASR prompt, type the following command to deactivate the asset:
    asr> deactivate_asset -i asset-IP-address asset
    where asset-IP-address is the Oracle ILOM IP address of the asset and asset is the name of the asset: fmm, node, or switch.
    A compute node IP's range is from 10.10.0.2 to 23 and 25 to 32.
Related Information
