In the same position as originally installed, attach the top PDU bracket
to the modular system using a T-30 Torx screwdriver.
Earlier you noted the location.
Note -
Make sure you place the bottom PDU bracket inside the
modular system, and when adding the top PDU bracket, also have the
PDU inside that top bracket.
