Go to main content
oracle home
Netra Modular System Service Manual Supplement
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Netra Modular System Documentation Library
Servicing the System Components
Identifying Component Locations and Slot Numbers
Component Slot Numbers
Updated: December 2016
Document Information
Using This Documentation
Product Documentation Library
Feedback
Monitoring Faults
Modular System LEDs
Oracle Server X5-2M LEDs
Oracle Server X6-2M LEDs
Fault Monitoring Documentation
Safety and ESD Precautions
Front Components
Rear Components
Component Types and Service Classifications
Replaceable CRUs
Replaceable FRUs
Activating and Deactivating System Assets
Deactivate an ASR Asset
Activate an ASR Asset
Replace an FBS PCB
Replacing the FMM
Remove the FMM
Install the FMM
Replacing the RJ-45 Coupler Panel
Remove the RJ-45 Coupler Panel
Install the RJ-45 Coupler Panel
Replacing the MPO Coupler Panel
Remove the MPO Coupler Panel
Install the MPO Coupler Panel
Replacing the System Status LED Panel
Remove the LED Panel
Install the LED Panel
Servicing the FBA and Cables
Remove the FBA
Install the FBA
Replace a Faulty Cable
Remove or Install a Filler Panel
Getting Help
Contact Support
Master Serial Number Location
Servicing an Oracle Server X5-2M
Related Oracle Server X5-2M Documentation
Oracle Server X5-2M Differences
Oracle Server X5-2M Features
Oracle Server X5-2M Front Components
Oracle Server X5-2M Removed From System
Oracle Server X5-2M CRUs
Oracle Server X5-2M FRUs
Oracle Server X5-2M Service Labels
Oracle Server X5-2M Fault Troubleshooting
Prepare an Oracle Server X5-2M for Service
Removing and Installing an Oracle Server X5-2M
Remove an Oracle Server X5-2M
Install an Oracle Server X5-2M
Power Down an Oracle Server X5-2M
Install and Update Software on an Oracle Server X5-2M
Return an Oracle Server X5-2M to Oracle
Servicing an Oracle Server X6-2M
Related Oracle Server X6-2M Documentation
Oracle Server X6-2M Differences
Oracle Server X6-2M Features
Oracle Server X6-2M Front Components
Oracle Server X6-2M Removed From System
Related Information
Oracle Server X6-2M Rear Components
Oracle Server X6-2M CRUs
Oracle Server X6-2M FRUS
Oracle Server X6-2M Service Labels
Oracle Server X6-2M Fault Troubleshooting
Prepare an Oracle Server X6-2M for Service
Removing and Installing an Oracle Server X6-2M
Remove an Oracle Server X6-2M
Install an Oracle Server X6-2M
Power Down an Oracle Server X6-2M
Install and Update Software on an Oracle Server X6-2M
Return an Oracle Server X6-2M to Oracle
Servicing PDUs
Related PDU Documentation
Troubleshooting a PDU
PDU Circuit Breaker Overview
Switch On or Off a PDU Breaker
Preparing for PDU Service
Safety Notices
ESD Precautions
PDU Physical Specifications
PDU Electrical Specifications
Tools Needed for Servicing a PDU
Attach an Antistatic Wrist Strap
Replacing a PDU
Troubleshoot the Fault and Follow Safety Precautions
Power Off and Disconnect Components
Provide Access to a PDU
Remove a PDU
Install a Replacement PDU
Connect and Install Adjacent Components
Return the Modular System to Previous Location
Power On the System
Metering Unit Restriction
Servicing Ethernet Switches
Related Switch Documentation
Switch Locations and Models
Switch and Node Configurations
Replacing Switches
Remove an Ethernet Switch
Install an Ethernet Switch
Replacing the Ethernet Transceiver
Remove an Ethernet Transceiver
Install an Ethernet Transceiver
Servicing Cords and Cables
Precautions for Handling Cords and Cables
Replace an Ethernet Cable From FMM to a Switch or a Coupler Panel
Replace an Ethernet Cable From FBS to a Switch or a Coupler Panel
Replace an Ethernet Cable From FBS to FMM
Replace a Fiber Cable from FBS to MPO Coupler Panel
Replace the DB-9 LED Cable
Replace an FMM Power Cord
FBS Power Cord Replacement Information
Replace an FBS Power Cord
Replace a Switch Power Cord
Replace a Fiber Shuffle Cable
Replace an FBH Cable
Identifying Port Mapping
FMM Software Ports
Identifying RJ-45 Coupler Panel Ports
FMM Serial Port
Multiple-System Configuration Ports
Ethernet Management Network Port
Other Network Ports
Ports to FBS PCB
Identifying MPO Coupler Panel Ports
Identifying Switch Ports
Copper Switch Slot 35 to FBS-PCB Ports
Copper Switch Slot 36 to FBS-PCB Ports
Switch Serial Ports to FBS-PCB Ports
Fiber Switch Slot 37 Ports
Fiber Switch Slot 38 Ports
Fiber Switch Slot 39 Ports
Fiber Switch Slot 40 Ports
Glossary
Index
Index A
Index C
Index D
Index E
Index F
Index H
Index L
Index M
Index N
Index P
Index R
Index S
Index T
Language:
English
Note -
In place of the optional fiber switches, slots 37-40 can contain MPO coupler panels (fiber).
Related Information
Front Components
Rear Components
Previous
Next
