Caution - Two persons are required to install the FMM, to prevent damage to the equipment and personnel. |
Caution - Make sure that the Ethernet cables are on top of the FMM when installing the FMM. |
Caution - Reconnecting the Ethernet cables incorrectly will cause connectivity issues and unpredictable system behavior. |
Make sure that the orientation is correct, with the shelf on top.
One pair of cables routes to the upper section (above the FMM) of the rack and will connect to the top ports on the FMM. The other pair of cables routes to the lower section of the rack (below the FMM) and will connect to the bottom two ports on the FMM.
