The Ethernet switches used in the modular system are documented separately. For a detailed service manual, switch-related safety precautions, and other documentation about the switches, refer to the Oracle Switch ES2-72 and Oracle Switch ES2-64 Documentation Library at:
http://docs.oracle.com/cd/E60179_01/index.html
Depending on the configuration ordered, your modular system has up to six Ethernet switches.
For more information about configuring switches, refer to Oracle Ethernet Switches L2 and L3 Deployment Best Practices.
