Go to main content
Netra Modular System Service Manual Supplement
Exit Print View
Updated: December 2016
Install the RJ-45 Coupler Panel
  1. Follow safety and ESD precautions.
    See Safety and ESD Precautions.
  2. Connect the internal cables to the correct ports, per cable labels.
    The correct ports are the ones that face the front of the modular system when the coupler panel is installed. These cables loop over the top of the coupler panel when installed properly. Refer to the labels on the cables.
  3. Carefully push the coupler panel back into the slot, keeping clear of the fiber cables.
  4. Using a No. 3 Phillips screwdriver, insert the four screws to attach the coupler panel to its mounting brackets.
  5. Reconnect the external cables, including any external cables the customer had connected, to the ports on the coupler panel.
    For the customer external cables, refer to the notes created earlier to reconnect cables to their previous locations.
  6. Resume applications that were stopped for the service.
Related Information
