Go to main content
Oracle® Exadata Storage Server X6-2 High Capacity Service Manual
Exit Print View
Updated: January 2018
Remove a Storage Drive
  1. Prepare the system for the drive removal.
    Refer to Take Antistatic Measures.
  2. Type the operating system commands required to stop the server from using the drive.
    The exact commands required depend on the configuration of your drives. Unmount file systems, or issue RAID commands as needed.
    Note -  The blue OK to Remove status indicator LED on the drive may or may not light, as support for this varies depending on the operating system in use.
  3. Identify the location of the drive that you want to remove.
    The following illustrations show the location of the drives and the internal system software designations for the drives. For information on storage drive status indicators (LEDs), refer to Storage and Boot Drive Indicators.
    image:Figure showing the location and numbering of drives on a server with twelve 3.5-inch drives.
    Figure Legend
    Description
    Figure Legend
    Description
    1
    Storage drive 8 (HDD)
    7
    Storage drive 10 (HDD)
    2
    Storage drive 4 (HDD)
    8
    Storage drive 6 (HDD)
    3
    Storage drive 0 (HDD)
    9
    Storage drive 2 (HDD)
    4
    Storage drive 9 (HDD)
    10
    Storage drive 11 (HDD)
    5
    Storage drive 5 (HDD)
    11
    Storage drive 7 (HDD)
    6
    Storage drive 1 (HDD)
    12
    Storage drive 3 (HDD)
  4. On the drive you plan to remove, push the latch release button [1] to open the drive latch [2].
    image:Figure showing the location of the storage drive release button and latch.
    Caution
    Caution  -  The latch is not an ejector. Do not open the latch too far to the right. Doing so can damage the latch.
  5. Grasp the latch and pull the drive out of the drive slot.
    image:Figure showing a storage drive being removed from the server.
  6. Consider your next steps:
    • If you are replacing the drive, continue to Install a Storage Drive.
      Caution
      Caution  -  Whenever you remove a storage drive, you should replace it with another storage drive; otherwise, the server might overheat due to improper airflow.
Related Information
