Go to main content
oracle home
Oracle
Exadata Storage Server X6-2 High Capacity Service Manual
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Oracle Server X6-2L Documentation Library
Oracle
Exadata Storage Server ...
Monitoring Components and Identifying SNMP ...
Physical Security Events
Updated: January 2018
Oracle
Document Information
Using This Documentation
Product Documentation Library
Feedback
About the Oracle Exadata Storage Server X6-2 High Capacity
Product Description
About Controls and Connectors
Front Panel Components
Rear Panel Components and Cable Connections
About System Components
Illustrated Parts Breakdown
Field-Replaceable Units
Troubleshooting and Diagnostics
Troubleshooting Server Component Hardware Faults
Troubleshooting Server Hardware Faults
Basic Troubleshooting Process
Related Information
Troubleshoot Hardware Faults Using the Oracle ILOM Web Interface
Troubleshooting and Diagnostic Information
Troubleshooting Using the Server Front and Rear Panel Status Indicators
Related Information
Server Boot Process and Normal Operating State Indicators
Server System-Level Status Indicators
Server Fan Status Indicators
Storage and Boot Drive Indicators
Power Supply Status Indicators
Network Management Port Status Indicators
Ethernet Ports Status Indicators
Motherboard Status Indicators
Troubleshooting System Cooling Issues
External Ambient Temperature Too High
Airflow Blockage
Cooling Areas Compromised
Hardware Component Failure
Troubleshooting Power Issues
AC Power Connection
Power Supplies (PSUs)
Top Cover
Managing Server Hardware Faults Through the Oracle ILOM Fault Management Shell
Troubleshooting With Diagnostic Tools
Diagnostic Tools
Diagnostic Tool Documentation
Attaching Devices to the Server
Attach Devices to the Server
Rear Panel Connector Locations
Configuring Serial Port Sharing
Assign Serial Port Output Using the CLI
Assign Serial Port Output Using the Web Interface
Ethernet Port Boot Order and Device Naming
Ethernet Port Device Naming
Rear Panel Pinhole Switches
Getting Help
Contacting Support
Related Information
Locating the Chassis Serial Number
Preparing for Service
Safety Precautions
Safety Symbols
Electrostatic Discharge Safety
FRU Key Identity Properties (KIP) Automated Update
Related Information
Required Tools
Preparing the Server for Component Replacement
Powering Down the Server
Power Down the Server for Immediate Shutdown Using the Power Button
Power Down the Server for Immediate Shutdown Using the Oracle CLI
Power Down the Server for Immediate Shutdown Using the Oracle ILOM Web Interface
Disconnect Cables From the Server
Extend the Server to the Maintenance Position
Remove the Server From the Rack
Take Antistatic Measures
Remove the Server Top Cover
Remove the Fan Assembly Door From the Server
Servicing Components That Do Not Require Server Power-Off
Servicing Storage Drives and Rear Drives
Storage Drives Hot-Plug Conditions
Remove a Storage Drive
Install a Storage Drive
Servicing Fan Modules
Remove a Fan Module
Install a Fan Module
Servicing Power Supplies
Remove a Power Supply
Install a Power Supply
Servicing Components That Require Server Power-Off
Servicing the DIMMs
DIMM and Processor Physical Layout
DIMM Population Rules
Inconsistencies Between DIMM Fault Indicators and the BIOS Isolation of Faulty DIMMs
Using the Storage Server Fault Remind Button
Identify and Remove a Faulty DIMM
Install a DIMM
Servicing PCIe Cards
PCIe Slot Locations
Remove a PCIe Card
Install a PCIe Card
Servicing the Internal USB Flash Drive
Remove the Internal USB Flash Drive
Install the Internal USB Flash Drive
Servicing the Battery
Remove the Battery
Install the Battery
Servicing Processors
Processor Removal and Replacement Tool
Remove a Processor
Install a Processor
Servicing the Storage Drive Backplanes
Remove the Storage Drive Backplane
Install the Storage Drive Backplane
Servicing SAS Cables
Remove SAS Storage Drive Cables
Install SAS Storage Drive Cables
Servicing the Oracle Storage 12 Gb/s SAS PCIe RAID HBA Card
Remove the Sun Storage 12 Gb/s SAS PCIe RAID HBA Card
Install the Oracle Storage 12 Gb/s SAS PCIe RAID HBA Card
Servicing the Front LED/USB Indicator Modules
Remove the Left LED Indicator Module
Install the Left LED Indicator Module
Remove the Right LED/USB Indicator Module
Install the Right LED/USB Indicator Module
Servicing the Motherboard Assembly
Remove the Motherboard Assembly
Install the Motherboard Assembly
Install the Server Top Cover
Install the Fan Assembly Door
Remove Antistatic Measures
Reinstall the Server in the Rack
Return the Server to the Normal Rack Position
Reconnect Power and Data Cables
Power On the Server
Identifying the Server Ports
Gigabit Ethernet Ports
Serial Management Port
Video Connector
USB Ports
Setting Up BIOS Configuration Parameters
Managing the BIOS Configuration
Accessing the BIOS Setup Utility
BIOS Setup Utility Menus
BIOS Key Mappings
Access BIOS Setup Utility Menus
Navigate BIOS Setup Utility Menus
Using UEFI
Selecting Legacy BIOS or UEFI Boot Mode
Switching Between Legacy BIOS and UEFI Boot Modes
UEFI Boot Mode Advantages
Configuration Utilities for Add-In Cards
Using BIOS for Resource Allocation
Legacy Option ROM Allocation
Common BIOS Setup Utility Tasks
Verify BIOS Factory Default Settings
Select Legacy BIOS or UEFI BIOS Boot Mode
Select the Boot Device
Configure TPM Support
Configure SP Network Settings
Configure Option ROM Settings
Configure I/O Resource Allocation
Exit BIOS Setup Utility
BIOS Setup Utility Menu Options
BIOS Main Menu Selections
BIOS Advanced Menu Selections
BIOS Advanced Menu Processor Configuration Options
BIOS Advanced Menu CPU Power Management Configuration Options
BIOS Advanced Menu Memory Configuration Option
BIOS Advanced Menu USB Ports Options
BIOS Advanced Menu Serial Port Console Redirection Options
BIOS Advanced Menu Trusted Computing Options
BIOS Advanced Menu Network Stack Options
BIOS Advanced Menu BMC Network Configuration Options
BIOS Advanced Menu iSCSI Configuration Options
BIOS Advanced Menu Ethernet Controller Options
BIOS IO Menu Selections
BIOS IO Menu PCI Subsystem Settings Options
BIOS IO Menu IO Virtualization Options
BIOS IO Menu I/OAT Configuration Options
BIOS IO Menu Internal Devices Options
BIOS IO Menu Add In Cards Options
BIOS Boot Menu Selections
BIOS Exit Menu Selections
Monitoring Components and Identifying SNMP Messages
Monitoring Component Health and Faults Using Oracle ILOM
Monitoring System Components
System Chassis Components
Cooling Unit Components
Disk Backplane Components
Memory Device Components
Power Unit Components
Processor Components
System Board Components
System Firmware Components
Hard Disk Drive Components
Identifying SNMP Trap Messages
Environmental Events
Hard Disk Drive Events
Power Events
Fan Events
Memory Events
Entity Presence Events
Index
Index A
Index B
Index C
Index D
Index E
Index F
Index G
Index H
Index I
Index L
Index M
Index N
Index O
Index P
Index R
Index S
Index T
Index U
Index V
Index W
Language:
English
Messages and Descriptions
Component Name
SNMP Trap:
sunHwTrapSecurityIntrusion
Oracle ILOM Event Message:
Assert
Severity and Description:
Major; General Chassis intrusion asserted.
/SYS/INTSW
