Go to main content
Oracle® Exadata Storage Server X6-2 High Capacity Service Manual
Exit Print View
Updated: January 2018
Gigabit Ethernet Ports
The server has four auto-negotiating 100/1000/10GBASE-T Gigabit Ethernet (GbE) system domain ports. All four Ethernet ports use a standard RJ-45 connector. The transfer rates are shown in the following table.
Table 7  Ethernet Port Transfer Rates
Connection Type
IEEE Terminology
Transfer Rate
Fast Ethernet
100BASE-T
100 Mbps
Gigabit Ethernet
1000BASE-T
1,000 Mbps
10 Gigabit Ethernet
10GBASE-T
10,000 Mbps
The following figure and table describe the 10-GbE port pin signals.
image:Figure showing the 10GbE port pin signals. Table 8  10-GbE Port Signals
Pin
Signal Description
Pin
Signal Description
1
Transmit/Receive Data 0 +
5
Transmit/Receive Data 2 –
2
Transmit/Receive Data 0 –
6
Transmit/Receive Data 1 –
3
Transmit/Receive Data 1 +
7
Transmit/Receive Data 3 +
4
Transmit/Receive Data 2 +
8
Transmit/Receive Data 3 –
Related Information
