Go to main content
Oracle® Exadata Storage Server X6-2 High Capacity Service Manual
Exit Print View
Updated: January 2018
Remove a Fan Module
You do not have to power off the server to service fan modules.
You should not begin this procedure unless you have a replacement fan module and you are ready to install it right away.
Caution
Caution  -  When removing and replacing a fan module in the system, you must complete the entire procedure within 20 seconds to maintain adequate cooling within the system. Remove and replace only one fan module at a time. Ensure that you have obtained the replacement fan module and that is it is ready for installation before starting the replacement procedure. Each fan module contains two fans, with two fan motors per fan. The four fan motors provide separate tachometer signals so that the fan module reports four tach signals to Oracle ILOM. Even if only one fan motor is faulted within the fan module, the Oracle ILOM service processor detects that four fan motors have failed to spin while the fan module is removed. If the fan module is not replaced within 20 seconds of removal, Oracle ILOM will take the protective action to shut down the system to prevent thermal damage to the system.
  1. Extend the server to the maintenance position.
    See Extend the Server to the Maintenance Position.
  2. To access the fan modules, open the top cover fan assembly door.
    Caution
    Caution  -  Close the top cover fan assembly door within 60 seconds to maintain adequate airflow to properly cool the server. Leaving the door open for more than 60 seconds, while the server is running, will cause the server to automatically shut down.
  3. Identify the faulty fan module.
    Each fan module has a fan status indicator (LED) that is located next to the module. If the LED is amber, the fan has failed. The location of the fan status LED is shown in the following figure.
    image:Figure showing the location of fan modules and associated status indicators.
  4. Use a No. 2 Phillips screwdriver to loosen the captive screw that secures the faulty fan module in the chassis [1].
    image:Figure showing how to remove a fan module.
  5. Grasp both the captive screw and the opposite end of the module and lift the fan module straight up and out of the chassis, and set it aside on an antistatic mat [2].
    Caution
    Caution  -  When removing a fan module, do not rock it back and forth. Rocking the fan module can cause damage to the motherboard connectors.
    Caution
    Caution  -  Do not service any other components in the fan compartment unless the system is shut down and the power cords are removed.
  6. Consider your next step:
    • If you removed the fan assembly as part of another procedure, return to that procedure.
    • Otherwise, continue to Install a Fan Module.
Related Information
