Go to main content
Oracle® Exadata Storage Server X6-2 High Capacity Service Manual
Exit Print View
Updated: January 2018
UEFI Boot Mode Advantages
When the option is available to choose between a Legacy BIOS Boot Mode or UEFI BIOS Boot Mode operating system installation, the advantages to choosing a UEFI BIOS Boot Mode installation include the following:
  • Avoids Legacy Option ROM address constraints. For more information, see Legacy Option ROM Allocation.
  • Supports operating system boot partitions greater than 2 terabytes (2 TB) in size. For more information about limitations for supported operating systems, refer to the Oracle Server X6-2L Product Notes at http://www.oracle.com/goto/x6-2l/docs.
  • Integrates PCIe device configuration utilities within the BIOS Setup Utility menus. For more information, see BIOS Setup Utility Menu Options.
  • Displays bootable operating system images in the boot list as labeled entities, for example, you will see a Windows boot manager label as opposed to raw device labels.
Related Information
