This mode performs targeted testing of system components and modules. In this mode, the test puts the maximum stress on the component or module under test. The tests are not run simultaneously with other tests: all tests are run sequentially. No other user application should be running on the system. The characteristics of the tests in this mode are as follows:
Intrusive: The tests can be intrusive in nature. The tests might need specific system configuration settings to run efficiently.
Data Safe: The tests are data safe by default.
The tests assume that the complete system resources are at their disposal and can use resources according to its needs.
