Oracle VTS 8.1.0 Software User's Guide
Exit Print View
Updated: June 2016
Change the Screen Resolution
The display resolution must be 1280x1024.
  • Type:
    # fbconfig -res 1280x1024x76
    Note - To perform graphics test on kfb frame buffers, the desktop must be running on each kfb device in the system.
    To run the Graphics test on an x86 system, you must start the GUI or TTY and run the Graphics test at the system console, or use the Java remote console from Oracle ILOM. See Start the Software (GUI).
    Note - On some systems, Graphics test may might need to be enabled. If the test is not enabled, a “not supported” message is displayed on the UI. By default, Graphics test is disabled on some systems. To re-enable the test, select the “Graphics Options”, scroll down to “Device Options”.
Related Information
