Exit Print View
Use these pin connections for 9-pin RS-232 and RS 423 port to 9-pin RS-232 and RS-423 port cables. Both plugs are male.
This cable has no part number assigned to it.
Test Connector Overview
25-Pin Port A-to-Port B Plug
25-Pin Port A-to-A Port B-to-B Plug
9-Pin Male Single-Port Plug
9-Pin Female Single-Port Plug
NT to TE Cable
TPE Cable for Fast Ethernet
TPE Cable for Gigabit and 10/100 Ethernet
9-Pin Male DB-9 External Connector
9-Pin Female DB-9 External Connector
