Oracle VTS 8.1.0 Software User's Guide
Exit Print View
Updated: June 2016
Live-Network Port Testing Settings
By default, the Network ports that are plumbed and connected to a live network are not tested to avoid network congestion. These setting can be changed as described in Io_Interconnect Test Options Through Configuration File.
Note - After you enable or disable live-network port testing, you must reprobe or restart the software.
Related Information
