Exit Print View
The test supports the options through the /etc/sunvts/conf/sunvts.conf configuration file. For more details on the options supported, see Supported Configuration Parameters.
Io_Interconnect Test Mode
Io_Interconnect Test Setup
Live-Network Port Testing Settings
