./vts_cmd get_global_options
The global options that apply to all the tests are displayed. The parameters for the global options includes:
Duration of testing (in minutes)
Verbose option (enabled or disabled)
Duration of logging (in minutes)
Safe testing option (enabled or disabled)
./vts_cmd set_global_options [Duration of Testing:<numeric value>,Verbose:<Enable or Disable>, Duration of Logging:<numeric value>, Safe Testing:<Enable or Disable>]
You can determine the values from the options listed by the get_global_options command, as per testing requirements. A confirmation message with the word DONE in it verifies that the operation was successful.
