Oracle VTS 8.1.0 Software User's Guide
Exit Print View
Updated: June 2016
Host Bus Adapter Test Configuration File Parameters
Parameter
Description
HBA_LOOPBACK
Parameter to specify the loopback mode for both Emlx and qlc tests.
For example:
HBA_LOOPBACK deviceX=Internal/External
HBA_Ignore_Target
Parameter to disable testing on a specific emlx or qlc port.
For example:
HBA_Ignore_Target emlxs0=IgnoreHBA_Ignore_Target qlc0=Ignore
Related Information
