To list the tests that are successfully probed by the system, type:
./vts_cmd list_tests
The details include information on whether the test is selected or not, its scheduling policy (time or pass based), the stress factor (high or low), the progress percentage of the test (when executed), and its status (idle, testing, completed, or failed).
To enable a particular test or all tests, type:
./vts_cmd enable_test testname/all
where testname is a test that you want to run, for example, Processor. If testname is a variable, use the replacement element. Using the all option executes all the available tests. A confirmation message with the word DONE in it verifies that the operation was successful. If the command fails, an error string is displayed along with the usage help.
To disable a particular test or all tests, type:
./vts_cmd disable_test testname/all
